Issues after replacing the turn signal switch?
THERESASUE
  • 2001 GMC SIERRA
  • 5.3L
  • V8
  • 4WD
  • 300,000 MILES
I replaced blinker switch. Because I had no dim light it fixed the problem. But a few days later I went out to finish putting the dash back together and it would turn over but not start. So, I figured it was the TBC fuse for the security lock out thing again. So, a few days later got fuse put it in. Fob would work, no dash lights, I had binging with key for a little bit. Emergency flasher I could hear but not see. Now nothing.
Saturday, January 27th, 2024 AT 1:29 PM
  • 108,401 POSTS
It sounds like the battery is discharged. Have you checked? I say that because you may have caused a short at some point and it is draining the battery.
If possible, take a voltmeter or multimeter and see how much voltage is present in the battery. Or try this simple load test on the battery and let me know what you find:
If you have a jumper pack or a means to try jump-starting the engine, give that a try as well. You could also remove the battery and have it load-tested at a parts store. Most do it free of charge.
Let me know what you find.
Saturday, January 27th, 2024 AT 9:08 PM
