Battery draining so alarm goes off
JOANNE ACKROYD-YATES
  • 2013 NISSAN 180SX
  • TURBO
  • 31,000 MILES
I keep charging the battery of my 370z Nismo nearly every night but after I have driven for a short while, then park up and lock, the alarm goes off every ten minutes.
There is an odd thing happening, if I put the car in reverse and the reverse camera comes on, the in-car battery volt metre reads 14, when I take it out of reverse, it goes down to 13. Please help, is this an electrical fault, how can I fix this- problems always seem to happen just after the warranty runs out.
Thanks,
Jo
Friday, October 28th, 2016 AT 4:42 AM
HMAC300
  • 48,600 POSTS
We do not have that model in USA so no real information on it. However I am going off of a Sentra here it has a battery current sensor on negative cable as well as a module either of those could be a problem. So a mechanic will need to scan for codes. You might contact the dealer to see If there are any service bulletins on your problem as this may be covered.
Friday, October 28th, 2016 AT 7:13 AM
