Automatic transmission
ALCAPONE2273
  • 2003 FORD FOCUS
  • 2.0L
  • 4 CYL
  • FWD
  • 130,000 MILES
The first time you start the car it has a lazy shift into third gear, worse if you drive slow after that it shifts fine tell you shut it off and let it sit overnight. I have noticed when you start it up and it will have a slow shift into third and then it is fine after that cannot figure this out every gear works fine except third the first the time you start the car.
Monday, August 1st, 2016 AT 6:39 AM
HMAC300
  • 48,600 POSTS
Have a transmission specialist scan for codes and check fluid it dark brown or black transmission may be on it way out or it may be a valve sticking in body.
Monday, August 1st, 2016 AT 6:47 AM
ALCAPONE2273
Oil is very clean and there are no codes. Now what?
Monday, August 1st, 2016 AT 4:51 PM
HMAC300
  • 48,600 POSTS
Have a transmission professional check for a valve sticking in valve body.
Tuesday, August 2nd, 2016 AT 5:35 AM
