After cleaning MAF sensor the engine will not crank over?
SHAOLIN167
  • 1991 MAZDA PROTEGE
  • 1.8L
  • 4 CYL
  • 168,000 MILES
I tried to clean the MAF (with MAF spray) and throttle body (throttle body cleaner) and placed seafoam fuel injector cleaner in gas tank because the car kept shutting off when turning or remain idling like at a light. So, I tried the cheapest way before taking it to a mechanic. The car attempted to start 3 times, the 4th time, and every time after for the last 8 hours has been a very low click like electric and no cranking. It won't start again.
Monday, April 17th, 2023 AT 10:36 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,351 POSTS
It sounds like the battery went bad but to be sure this guide can help you load test the battery:
And if it fails this guide can walk you through replacing the battery:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Make sure the cables are clean and tight.
Tuesday, April 18th, 2023 AT 9:03 AM
