Acellerator cable
FARMERJOE
  • 1996 CHEVROLET S-10
  • 2.2L
  • 4 CYL
  • RWD
  • MANUAL
  • 195,000 MILES
Sirs, the accelerator cable on my truck is fraying badly at the throttle body end. I cannot buy a new one as it is a discontinued part. Do you think the one for a 4.3 engine will fit as a replacement? Thanks, Joe
Saturday, August 26th, 2017 AT 1:47 PM
CJ MEDEVAC
  • 11,004 POSTS
Do not rule out your 4.3 idea.
This worked well the first time in a real pinch, and a couple of more times since.
The first time was really economical. The other two occasions were purchased from the same shop (during the day- still pretty cheap).
See my answer in this link.
https://www.2carpros.com/questions/1996-chevrolet-astro-do-you-have-a-video
Just be aware that there are several different cable sizes (diameters), one closest to your size would work the best. I only replaced the inner cables and the outer shrouds were reused.
Keep us informed!
The Medic
Saturday, August 26th, 2017 AT 7:14 PM
STEVE W.
  • 13,167 POSTS
The 4.3 cable is about one inch longer on the inner cable. But it will work if you "adjust" the brackets and the end clip a bit.
Sunday, August 27th, 2017 AT 12:49 PM
