Truck not accelerating properly?
SURFSIDE TRUCK
  • 1990 TOYOTA PICKUP
  • 3.0L
  • V6
  • 4WD
  • 2,500 MILES
Hesitates and jumps when accelerating, fine at speed, very slow acceleration.
Monday, July 18th, 2022 AT 5:04 PM
  • 108,432 POSTS
This could be a few things. For example, there could be a fuel supply issue, a partially plugged catalytic converter, the need for a tune up, and so on.
Here is where I want to start: Let's see if there are any diagnostic trouble codes that can point us in the right direction. This vehicle has an OBD1 system that doesn't require a scanner to retrieve codes. Follow the directions in this link and let me know what you find:
https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995
Let me know what you find.
joe
Monday, July 18th, 2022 AT 10:08 PM
