HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Century
Engine Cooling
Cooling Fan
Not Working
A/C compressor and cooling fan not working?
MARCEL00S
MEMBER
1995 BUICK CENTURY
3.1L
V6
2WD
AUTOMATIC
140,000 MILES
Cooling fan doesn’t work, and A/C compressor doesn’t engage.
Wednesday, April 26th, 2023 AT 11:01 PM
KEN L
MASTER CERTIFIED MECHANIC
This can be because the A/C system is low on charge.
Here is a video and a guide to help us fix the problem:
https://youtu.be/uZrQCGwXfek
and
Please go over these guides and report back.
SPONSORED LINKS
Thursday, April 27th, 2023 AT 5:12 PM
Please
login
or
register
to post a reply.
Related Cooling Fan Not Working Content
My Cooling Fan Only Runs With The A/c On
I Recently Acquired A 1987 Century With The 2.5l Engine. The Car Runs Great However The Cooling Fan Only Runs With The A/c On. I Checked A...
Asked by
csm1992
1 IMAGE
1987
BUICK CENTURY
Electrical Failure
With The Car Running When Cooling Fan Kicks On, But Not Every Time, But On Occasion The Car Will Idle Rough. Checked Fuel Pressure About...
Asked by
Kelly Maag
1 IMAGE
1993
BUICK CENTURY
Car Temp Lite ^ Check Engine Lite Comes On After 30...
Car Temp Lite ^ Check Engine Lite Comes On After 30 Minutes Then Car Shuts Off, Restarts After 20-30 Minutes Later. Temp Ok ( External Temp...
Asked by
ajwolfe
1993
BUICK CENTURY
I Have A Problem With My Temp Gage And Cooling Fans...
I Replaced The Lower Intake Gaskets On My Car. Now My Cooling Fans Won't Come On Unless I Unplug The Cooling Temp Senser And When I Plug...
Asked by
johnwayne20091
1994
BUICK CENTURY
1999 Buick Century Cooling Fan Control
Cooling Fans Do Not Start When Engine Gets Hot. Grounding Pins A3 Or A11 Causes Associated Fan To Run Ok So Fans, Fuses, And Relays Are...
Asked by
David Noble
1999
BUICK CENTURY
VIEW MORE
Online car repair manuals
