ABS/wheel speed sensor?
AKJOHNSON1027
  • 2016 NISSAN VERSA
  • 1.6L
  • 4 CYL
  • 66,700 MILES
I have gone through four wheel bearings now. Have replaced all brakes including the brake booster, master cylinder, and module, brake lines, wheel speed sensors, CV axle, calipers, etc. The ABS lights keep coming on claiming the wheel bearing is toast. I have a brand-new bearing and a brand new sensor and even tested the sensor to ensure it’s working.
Thursday, April 11th, 2024 AT 2:45 PM
CARADIODOC
  • 33,760 POSTS
Diagnostic fault codes never say a part is defective. They only indicate the circuit or system that needs further diagnosis. What are the exact fault code numbers?
What is happening with the wheel bearings? Do they make a buzzing noise? Do they become sloppy? What led you to replace all the other parts? Is there any related history that led up to this problem? What are the exact symptoms, and do any of the new parts make those symptoms go away for a little while?
Thursday, April 11th, 2024 AT 3:05 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,288 POSTS
What is the code number?
Thursday, April 11th, 2024 AT 6:12 PM
