Car starts and upon first acceleration the car grinds a bit then it goes away. My mechanic said it’s a wheel bearing and speed sensor but I’m not sure what this grinding noise is.
Wednesday, May 17th, 2023 AT 11:35 AM
STEVE W.
MECHANIC
The light means that the ABS sensor isn't able to read the wheel speed and coupled with a grinding noise from a wheel bearing would point to that one being the problem. The wheel bearing is failing and will need to be replaced, That should repair both problems at the same time.
