It dings then ABS and brake lights turn on
FREDERICK SULLIVAN
  • 2005 CHRYSLER PACIFICA
  • 79,191 MILES
The ABS and brake light's come on then off dash light's flickering and twice it wanted to stall out and low voltage.
Friday, June 19th, 2020 AT 5:33 PM
  • 108,524 POSTS
If I understand, you hear a ding and then the ABS light comes on as well as the brake light. Is that correct? If so, the first thing I need you to check is the brake fluid level. If it is low enough, it will set an ABS light / Brake light. Let me know that first. If it is full, chances are there is a faulty wheel speed sensor.
As far s the low voltage, can you tell me exactly what is happening? If there is low voltage due to a battery issue or alternator, that can cause several different components to malfunction.
Let me know. Also, if you what, here is a link that explains how to test an alternator. If you have a chance, do this and let me know the results.
Let me know what you find.
Friday, June 19th, 2020 AT 6:10 PM
FREDERICK SULLIVAN
  • 3.5L
  • 79,191 MILES
Vehicle listed above is an all wheel driver. It dings then ABS, break light's come on and off the light on dash flickering and it low voltage. It wanted to stall out twice.
Saturday, June 20th, 2020 AT 1:42 PM (Merged)
  • 52,797 POSTS
Good morning,
Low voltage from a bad battery or failing charging system will cause the light to come on.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
I would start by load testing the battery, checking the charging system, and then if the light still comes on, check it for codes.
