• HOME
  • ASK A QUESTION
  • REPAIR GUIDES
  • BECOME A MEMBER
  • LOG IN
    Login with Facebook
    OR
    NOT A MEMBER?FORGOT PASSWORD?
  • CONTACT US
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
  • Home
  • GMC
  • Safari
  • Ignition
  • Firing Order
Firing Order 1988 4.3 V6
MCUDDY
  • 1988 GMC SAFARI
What is the firing order for a 1988 GMC Safari 4.3 V6 non Vortec? Also need Firing Diagram.
Saturday, September 22nd, 2007 AT 7:56 PM
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_mitchel_25.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_fireo_1.jpg
Saturday, September 22nd, 2007 AT 8:08 PM
Related Firing Order Content
2000 Gmc Safari Miss On Cylinder #4
The Other Night I Was Driving Home And The Throtle Control Cabel That Connect From The Accelerator Pedal To The Engine Broke In Half. I Had...
Asked by warik ·
2000
GMC SAFARI
1998 Gmc Safari No Spark
Electrical Problem 1998 Gmc Safari 6 Cyl Four Wheel Drive Automatic 240k Miles No Error Codes, Cam Sensor Is Fine, Crank Sensor Is...
Asked by rigidride ·
1 ANSWER
1998
GMC SAFARI
2003 Gmc Safari No Fire To Coil
I Got Voltage Off The Pink Wire. But I Cant Get A Pulse From The White Wire. What Can I Check Now?
Asked by gary rhoades ·
1 ANSWER
2003
GMC SAFARI
1986 Gmc Safari Timing
I Need To Set The Timing On My Van Because Someone Hade Decided To Turn The Shaft And Did Not Mark The Spot. So When It Was Turned I Have No...
Asked by darla357 ·
1 ANSWER
1986
GMC SAFARI
Timing Issue
If The Timing Is Set Back In A Gmc Safari With 222, 76 Miles And A Vortec Motor, Will The Motor Die Soon?
Asked by leericky ·
1 ANSWER
2000
GMC SAFARI
VIEW MORE
Spark Plug Replacement Mercedes Benz
Spark Plug Replacement Ford Escape V6 3.0L
  • Contact
  • Help
  • About
  • Privacy Policy
  • Terms & Conditions
© 1999 - 2026 2CarPros, Inc.
