3500
This van has had intermittent/erratic speedometer operation for 3-4 months now and now the transmission won't shift. I have no upshift from first gear, either automatically or manually using the column shift. I serviced the transmission; no clutch material or metal in the pan and the filter was okay, fluid had burnt smell to it. I checked the vehicle speed sensor resistance at 1,328 ohms; the slip ring inside the trans was tight and had no lateral movement that might give an erratic signal. I couldn't read any voltage to the VSS, either alternating or direct current. Please advise as soon as possible, trying to get it running for a customer.
SPONSORED LINKS
Tuesday, February 24th, 2009 AT 8:29 PM
