2004 Toyota Camry CD stuck in 6 CD changer
SAMARTH
  • 2004 TOYOTA CAMRY
  • 6 CYL
  • AWD
  • 30,000 MILES
Y'day I loaded all 6 CDs in the 6 CD changer. After this, I could not eject/load/play any of the CD. The display on cd #2 blinks and later get the ERR3 on the CD display. Any idea how to remove the already loaded CDs? AM/FM works without any issues. When I turn on the engine, the CD player seems to make a sound like as if its about to load the CD and this noise remains for quite sometime. Please help.
Wednesday, August 5th, 2009 AT 12:40 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,469 POSTS
Hey Samarth,
Yep these CD players get jammed up sometimes, you can use a small pair of tweezers to remove the last CD install through to installation slot. If you cannot get to the CD remove the unit and disassemble it to remove the CDS, and then reassemble it and try it again. What happens is the cartridge gets a small piece of dirt in it and jams one of the CD.S
Please let us know happens so it will help others.
Best, Ken
Friday, December 2nd, 2016 AT 3:50 PM
