Master cylinder replacement
JAMESMMJ
  • 2001 ISUZU RODEO
  • 3.2L
  • V6
  • 200,000 MILES
I have replaced the master cylinder, but I cannot get the brake lines to bleed. What is the proper bleeding procedure on my vehicle?
Thursday, May 11th, 2017 AT 7:42 AM
HMAC300
  • 48,600 POSTS
Try a power bleeder first it may work otherwise a mechanic is going to have to use his scanner to open valves on ABS unit so it can be bled.
Thursday, May 11th, 2017 AT 9:40 AM
