1992 Honda Civic Hybrid
ISLANDER671
  • 1992 HONDA CIVIC HYBRID
Engine Performance problem
1992 Honda Civic Hybrid 4 cyl Two Wheel Drive Manual
I'm in need of your advice. I have AQ 92 Honda Civic Lx did a motor swap with a d15b Jdm. I running the P08 ecu did using the 1 wire 02 sensor. The problem is when I put my car in gear and take of the engine loses power it starts sounding funny. But when on nuetral the engine sounds greatit seems it only happens when I put a load on the engine. Please Help
Tuesday, August 31st, 2010 AT 10:46 PM
KHLOW2008
  • 41,814 POSTS
Hi iSlaNdeR671,
Check the ignition timing. If the correct ignition timing cannot be achieved by turning the distributor, the timng belt has been installed incorrectly.
Wednesday, September 1st, 2010 AT 1:22 PM
ISLANDER671
Just checked the timing everything is in order
Sunday, September 5th, 2010 AT 12:23 PM
KHLOW2008
  • 41,814 POSTS
With correct ignition and valve timing, the next would be to test the fuel pressure.
Monday, September 13th, 2010 AT 8:21 AM
ISLANDER671
It was the wire harness that I switched out. Put the original one back & everything was great. I Do Appreciate your help thanks.
Monday, September 13th, 2010 AT 4:10 PM
