HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Oxygen Sensor
Replace/Remove
1998 Toyota Corolla REPLACING O2 SENSOR
MYSTICBLUE98LE
MEMBER
1998 TOYOTA COROLLA
4 CYL
FWD
MANUAL
192,000 MILES
CAN I REPLACE A CATALYTIC CONVERTER AND A O2 SENSOR MYSELF AND IF SO WHAT DO I NEED AND IS IT WORTH DOING IT MYSELF
Tuesday, September 7th, 2010 AT 6:50 PM
MMPRINCE4000
MECHANIC
Many Toyota convertors are bolted in, if so, unbolt and replace. If welded in, then a shop will have to remove and re-weld.
The O2 sensor screws into a bung in exhaust. Disconnect and unscrew.
SPONSORED LINKS
Wednesday, September 8th, 2010 AT 7:49 AM
Please
login
or
register
to post a reply.
Related Oxygen Sensor Replace/Remove Content
1998 Toyota Corolla Oxygen Sensor
Will A Bad O2 Sensor Make The Engine Misfire Badly? If So Would It Likely Be The One Before Or After The Converter? I've Changed The...
Asked by
ell_p
1 ANSWER
1998
TOYOTA COROLLA
VIDEO
Oxygen Sensor Replacement
Instructional repair video
GUIDE
An oxygen or lambda sensor is used to determine the engine exhaust mixture which can then be controlled by the computer. These sensors are equipped with a heater that can...
Oxygen Sensor Replaced Three Times In One Month
A Month Ago I Replaced My Upstream Oxygen Sensor Due To Check Engine Light. Two Weeks Ago The Check Engine Light Came On Again, And The...
Asked by
Linnielev
2004
TOYOTA COROLLA
1996 Toyota Corolla
A Little Frustrated And Puzzled March 2010- Car Had Been Running Fine And Just Died Something Happened That Messed Up The Distributor We...
Asked by
kyhills
1996
TOYOTA COROLLA
1997 Toyota Corolla O2 Sensor Problem In 97' Corolla
I Am Replacing An O2 Sensor (the One Right Before The Cat) In My 97' Corolla. I Can Remove The Sensor From The Car Fine But I Cannot Get To...
Asked by
O2 sensor problem
1997
TOYOTA COROLLA
2001 Toyota Corolla Powers Down
Engine Performance Problem 2001 Toyota Corolla 4 Cyl Front Wheel Drive Automatic My Car Starts To Power Down More After I Have...
Asked by
leperchron
2001
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Oxygen Sensor Replacement Dodge
How to Read Codes Chevrolet
Online car repair manuals
