HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Drivetrain
Transmission
Clutch
Replace/Remove
SPONSORED LINKS
1994 Toyota Corolla Clutch replacement
TCHIPMAN70
MEMBER
1994 TOYOTA COROLLA
4 CYL
2WD
MANUAL
173,000 MILES
Need the diagram for transmission removal
Monday, August 30th, 2010 AT 6:59 AM
MMPRINCE4000
MECHANIC
What type of equipment do you have? Cherry picker, jack stands, floor jack?
SPONSORED LINKS
Monday, August 30th, 2010 AT 9:28 AM
TCHIPMAN70
MEMBER
1 POST
I have all of the above. Engine is suspended and loose. Just trying to get the brace out and its bound up
Monday, August 30th, 2010 AT 12:58 PM
MMPRINCE4000
MECHANIC
I take the transaxle out the top, engine and trans.
Most shops would suspend engine and remove trans.
Use cherry picker to pull transaxle out top.
Remove trans. And change rear main seal while it is apart.
What is bound up? The rear motor mount is the hardest to get out.
Tuesday, August 31st, 2010 AT 8:25 AM
Please
login
or
register
to post a reply.
Related Transmission Clutch Replace/Remove Content
1994 Toyota Corolla How To Replace The Clutch
I Need The Diagrams Of How To Replace The Clutch
Asked by
sparticus
1994
TOYOTA COROLLA
Clutch Replacement Pulled Over And Could Smell A Faint...
Assuming I Never Ride The Clutch. If The Clutch In My Car 'burns Out' At 28,000 Km, What Else Could Cause That? I Never Ride The...
Asked by
aimdesign
1 ANSWER
40 IMAGES
2008
TOYOTA COROLLA
1990 Toyota Corolla Clutch Replace
Mechanics Have Stated That A Clutch And Timing Belt Need To Be Replaced. The Timing Belt Broke And We Towed The Car To A Shop. There Has...
Asked by
joels
1990
TOYOTA COROLLA
How To Adjust Clutch Pedal
I Have Replaced The Clutchplate, Pressure Plate And Release Bearing On My Toyota Corolla 1.3 And Now The Clutch Only Engage Very Low Down...
Asked by
bertus de jager
2 IMAGES
1991
TOYOTA COROLLA
1992 Toyota Corolla Clutch Change, Labour Costs?
Transmission Problem 1992 Toyota Corolla 4 Cyl Front Wheel Drive Manual 220km Miles Hey There, My Clutch Has Gone As The Car...
Asked by
Botha
1992
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Clutch Pilot Bearing Replacement
Clutch Not Working
Throw out Bearing Replacement
Online car repair manuals
