Steering wheel shakes
STONERHYTHMS
  • 1999 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 123,700 MILES
Hi I have a 99 Camry CE and I am having issues with the steering wheel shaking. This isn't the entire time I drive it and will happen intermittently and sometimes I can drive for over an hour before it does the shaking thing. It does it mainly at speeds over 40-45 but will still shake even when I slow down to like 35 or 30. This is what I have had recently done that I thought might make it stop. I had both front rotors replaced. My passenger side front tire rod was bent and had both the inner and outer tire rods replaced. I had my torque strut engine mount replaced. Have had my car aligned 2 times and it has gotten 4 new tires and had them balanced also numerous times.
It was suggested to me to try and slip it into neutral when it is shaking and if the shaking stops it might be something in the drive train. Another site I saw it was suggested that it could be bent rims but I would think if it were the rims the shaking would happen all the time at speeds over 40-45. Anyways thanks in advance. They did tell me one of my tires had a "hop" to it so don't know if that means it is deforming or not. The only thing is even if the shaking doesn't happen for a while, when it does start shaking it will do it for like 5-10 minutes and then stop so if it was a deformed tire would it do it all the time? Thanks for your help :)
Tuesday, August 3rd, 2010 AT 9:55 PM
  • 31,937 POSTS
This sounds like you have a lower ball joint that is worn allowing the the steering wheel to shake here is a guide to help you see what I am talking about so you can get the problem fixed.
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Please run down this guide and report back
Cheers
Wednesday, August 4th, 2010 AT 2:36 AM
STONERHYTHMS
Thank you so much I took the car into the shop and they replaced both lower control arms the car has never worked better. Cost me $430.00 including the alignment
Wednesday, August 4th, 2010 AT 1:19 PM
  • 31,937 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Cheers
Wednesday, August 4th, 2010 AT 4:44 PM
