Front turn signal/parking light?
WRENCH_TURNER
  • 2009 DODGE CALIBER
  • 2.0L
  • V6
  • 100,000 MILES
Front driver side turn signal blinks normal at first then a few seconds later starts going fast I tried the socket and bulb on the passenger side both works fine when I switch it back to the driver side it with start acting up again. Help
Thursday, October 19th, 2023 AT 1:02 AM
  • 108,504 POSTS
It sounds like the rear bulb is bad. Did you check to see if the rear left signal is doing the same thing?
What you described is caused by an open circuit at some point in the wiring or a failed bulb. The fast flashing is normal and designed to do this as an indicator. Check all left bulbs to see if they are functioning and let me know what you find.
Thursday, October 19th, 2023 AT 5:57 PM
