1991 Ford F-150 Starting problems sometimes
CHARLESJONES
  • 1991 FORD F-150
  • V8
  • 50,000 MILES
5.8 liter engine. At home I park on a angle part on the drive and part on the grass so my wife can get out in the morning. I work at nights. The problem started after I changed out the air bypass valve and installed a new fuel filter. I used to be able to turn the key on and the truck would start ok. Now, If I miss hitting the gas when the engine first turns over it takes a long time to get it to start again. It doent matter which tank I have selected either. Once it gets warmed up and I leave it appears to choke a little after leaving a stop sign. Once at work and make the trip home it starts fine. Each time I try to start it I cycle the key off/on to activate the fuel pump again and it takes several tries to get it to start.
Wednesday, September 10th, 2008 AT 10:57 AM
JIMMIEJAMES
I'm having the exact same problem with my f150, even down to the cyclng the key on and off. I was wondering if you ever sourced the problem or not?
Thursday, October 2nd, 2008 AT 8:00 AM
CHARLESJONES
As silly as this may sound the cure was quite basic. I changed the distributor cap and rotor. Added a new fuel filter and stuck in a bottle to clean my injectors. Seemed to work for me. Good luck.
Thursday, October 2nd, 2008 AT 1:59 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,476 POSTS
The injector wires can be connected either way.
Friday, February 3rd, 2017 AT 4:13 AM
KEN L
  • 43,476 POSTS
Please let us know what happens so it will help others
Best, Ken
Monday, February 6th, 2017 AT 2:24 AM
