Engine will not start
DDOMINIQUE
  • 2000 CHEVROLET EXPRESS
  • 6 CYL
  • 120,000 MILES
Every time that I don't drive the van for 1 or 2 days it will not start unless I keep trying for at least 15 or 20 minutes. I did a complete tune up and when the switch is on I check the port and there is some pressure.
PS. When it starts everything is fine I can turn it off and start it again, no problem.
Thank you for your help.
Dominique
Wednesday, February 24th, 2010 AT 11:28 AM
JDL
  • 16,098 POSTS
Hi, when the problem occurs, have a helper crank it, while you visually check for spark at the plugs. If you spark everywhere, use a garage and check fuel pressure. Some of the national brand auto stores used to loan out a fuel pressure gauge.
Wednesday, February 24th, 2010 AT 3:13 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 43,476 POSTS
Can you hear the fuel pump running in the tank, try to smack the fuel tank to get the fuel pump working again?
Also check out this guide:
Let us know.
Wednesday, February 23rd, 2022 AT 9:09 AM
