Can a bad water pump cause code P0117?
MISCHE7
  • 2004 TOYOTA PRIUS
  • 120,000 MILES
Hi there. I am trying to sort out a problem that struck a couple of days ago. I had just gotten on the highway when the red triangle of heart pounding fear came on, followed by the overheating light. I got off the road at the next exit which was almost immediately available. Sitting at the light about 30 seconds later, the warning lights turned off. I slowly made my way to an auto parts store but there was no code to be read. I drove with very frequent stops to my destination with the same things happening. Using the engine to go up a hill earned me the lights and getting to about 40-45 mph did too. Stop for a minute, no lights. Also it’s worth saying that there was no clear overheating smell either. So near the destination the Che k engine light finally came on and I went directly to have the code read. P0117. I was excited it was probably just a sensor even if it’s going to be a terrible pain to get to. However I noticed the next morning that my serpentine belt was gone and discovered it mangled at the bottom of the engine housing. Too, it looked to me like there was very very little coolant. The overflow container was nearly empty and I didn’t see any by looking in the radiator. Anyway, ignoring that last bit other than adding more coolant, I was excited again because the serpentine belt is easy to fix and I figured that was probably causing all of the issues - not the sensor. I replaced it, filled the coolant and headed back from the original destination only to have the lights come on again. I made frequent stops, took back roads and did all I could to make sure the battery power in the car was used more than the engine. When I got home I saw that the serpentine belt was loose then noticed that it’s already been torn. I also noticed that the water pump pulley is absolutely not in line with the other two that the belt connects with. (Tensioner and the crankshaft pulleys) It appears that the top of the pump pulley is sort of leaning out and the bottom is closer to the engine than I think it normally is.
So I’m wondering if the water pump may have gone so bad, in fact, that it’s possibly crumpled in on itself. I know it could cause the loss of coolant (which I think I spotted at the bottom, though not on any pavement where I’ve parked) and of course the overheating symbol. The misalignment would be the culprit for eating the belts. I am planning to buy another water pump but if this brings some other issue to mind that I should consider I’m all ears! The only thing leading up to now that’s been noticeable is that the car has been using the engine much much more than it needs to. It’s always a relief when it shifts to the battery. That’s been going on for about a year or so.
In this image you can sort of see the alignment issue of the water pump pulley behind the tensioner pulley.
Monday, December 18th, 2023 AT 7:54 PM
  • 108,504 POSTS
The code indicates that the coolant temperature sensor was out of what is considered a normal range. That may have simply been due to overheating.
As far as the water pump, certainly the bearing in it may have failed and the pulley is tilted. With the belt removed, see if you can move the water pump pulley up and down or left to right.
Also, if you can take a pic and upload it for me to see, that may help.
Let me know what you find.
Monday, December 18th, 2023 AT 8:24 PM
MISCHE7
Hi Joe! Thanks for taking the time to write back. Sorry for the delay. Holidays!
So, it did turn out to be the water pump. Nothing else. I actually think it’s been going bad for some time now. With it replaced, the car is running more quietly than it has in some time. It felt like the engine was kicking in much more than it needed or ought to. Now the battery seems to get its time to shine and the engine kicks in when it seems appropriate. I do not like that the car had been struggling for so long without me realizing what the issue was. But it definitely seems better now.
Anyway, hopefully this will help someone else along the way too. Thanks again.
Tuesday, December 26th, 2023 AT 7:18 PM
  • 108,504 POSTS
I hope you had a nice Christmas. It was crazy here. LOL I can't believe it's over already.
Regardless, thank you for the update. I'm glad to know the problem was resolved. Chances are your reply will help others in the future.
Take good care of yourself and I wish you a great New Year! Feel free to come back anytime in the future.
Tuesday, December 26th, 2023 AT 9:33 PM
