HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Electrical
Alternator
Alternator brushes swap?
THISONE
MEMBER
2001 TOYOTA CAMRY
100,000 MILES
Will alternator brushes on a 2003 Grande Marquis interchange with a 2001 Toyota Camry?
Friday, October 13th, 2023 AT 10:50 PM
STEVE W.
MECHANIC
Not if the catalog is correct. It looks like the Denso brushes are 5mm X 7mm X 15mm while the Motorcraft brushes are about 2mm thicker and 1mm wider.
SPONSORED LINKS
Saturday, October 14th, 2023 AT 4:02 AM
Please
login
or
register
to post a reply.
Related Alternator Content
1991 Toyota Camry Battery And Alternator
I Would Appreciate It If You Can Answer My Questions. 1) If The Battery Is Not Properly In Place And Move, Will This Cause Alternator Or...
Asked by
sherdf
1 ANSWER
1991
TOYOTA CAMRY
VIDEO
Alternator Replacement
Instructional repair video
GUIDE
Alternator
An alternator is designed to supply electrical power (13.6 to 14.6 volts) to a vehicle when the engine is operating to recharge the battery back up for future use. This is...
87 Camry Alternator
I Have A 1987 Toyota Camry Station Wagon, 4cyl 2.0 Automatic Transmission A/c Power Steering, Front Wheel Drive. My Alternator Is Charging...
Asked by
rezaisahac
1 ANSWER
1987
TOYOTA CAMRY
1992 Toyota Camry Alternator Regulator
Electrical Problem 1992 Toyota Camry 4 Cyl Automatic My Battery Light On The Dash Was Flashing On And Off For About A Week Or So Then...
Asked by
bind247
1 ANSWER
1992
TOYOTA CAMRY
Battery Or Alternator Issue
My Car Died While Sitting At A Stoplight And It Would Not Restart. The Indicator Lights And Interior Lights Come On, But The Engine Does...
Asked by
Quincy Qdpie Perkins
1 ANSWER
2007
TOYOTA CAMRY
1989 Toyota Camry
I Pulled The Wires Out Of The Back Of My 89 Toyota Camry Alternator (generator Connector) There Are 3 Wires Black With Yellow Strip--white...
Asked by
jimstockton
1989
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
How to Test an Alternator
Alternator Test
Online car repair manuals
